跳转到主内容
加入维修社区 - 创建账户
Picture blinks on and off but the sound is fine
Picture keeps coming on and off but the sound is fine,is there a replacement board to fix the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @waltthompson,
What is the model number of the TV?
Can you view the TV menus OK without the screen blinking?
完成的
Flickering on an LG TV could be caused by various factors. It might be due to a loose cable connection, a malfunctioning power supply, or even a software issue. To diagnose the problem, I recommend checking the cable connections first and ensuring they are secure.
完成的
添加一条评论
1个答案
@waltthompson you are not giving us much to work with here. We do need to know what model your TV is. Returning a quick and dirty answer based on the information we have, this is not a board issue but a backlight issue. Your strips are turning off, cooling down and then coming back on. Replacing the backlight strips will resolve this. Sometimes you can determine if it is the strips by decreasing the brightness of the screen. If you set it to 50% or so and it stays on longer , you know it is the strips.
Now, this answer may change if more information becomes available.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Walt Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 263
