跳转到主内容
The Aspire 3 A315 is a repairable laptop by Acer.
21 个问题 查看全部
Replacement Screen Needed - What type?
Hey all! My mate gave me an Acer Aspire 3 A315-41-R540 with a cracked screen. I have found many replacement screens on eBay, but they often only say Acer Aspire A315 screen, or A315-22. I am unsure whether these screens will actually fit my model, as i noticed several differences. I will try to post an image of the model, and the screen, and the ribbon cable soon!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi @falcon16
Perhaps the most sure way to know that you're getting the correct one, is to disassemble the laptop and look for the model number (or part number) of the LCD panel which is usually found on the back of the panel itself.
Once you find the number, search online for the number, to find suppliers that suit you best.
Here's a teardown video that may help. At ~9:35 minutes into the video, you can see the stickers on the back of the panel, one of which may have the relevant information.
这个答案有帮助吗?
得分 2
2条评论:
So i found the sticker. It says InnoLux
N156BGA-EB2 Rev.C1
then the barcode
then 04C13G787C20372
And another barcode
then the first code again with C1 after it
完成的
@falcon16
Here are some suppliers that you can choose from when searching for InnoLux N156BGA-EB2 Rev.C1 lcd panel
Apologies if you've been there, done that ;-)
Cheers
完成的
添加一条评论
As far as I can see this kind of screen should be the right type for that model. Please double check the number against the ones on ebay before buying. Have had to order multiple times myself from ebay because I didn't double check.
https://www.zandparts.com/en/acer/notebo...
这个答案有帮助吗?
得分 1
9条评论:
hey, thank's for replying.
I checked and they are the right model, but wow! they are expensive! I was hoping for something a lot more affordable, even if it is used!
完成的
Yes, that is a reasonable price, but it doesnt ship to australia ;(
I will check out amazon tho, i dont know why i didnt think of that
完成的
Another question, the acer models are like such: A315-41-R540
Does it matter if the last section is different? One screen i found is A315-41-R3RF. Would it fit?
完成的
显示更多的4条评论
添加一条评论
One thing to note is that laptop makers generally don't make their own LCD screens; rather they almost always buy them off the shelf. The best way I've found to replace a broken one is to open it up and get to the back side of the LCD so you can take note of the actual manufacturer and model number of the LCD itself, regardless of what it's in.
Do a search based on that information rather than your laptop and there's quite often the chance you'll find other brands of computers that use that same screen, and at times they may be sold substantially cheaper than a replacement that says it's specifically for the laptop.
As an example, I went to replace an Acer Chromebook screen and found the same LCD used on a Compaq computer that I was able to get much cheaper than the ones being sold for the Acer.
这个答案有帮助吗?
得分 1
1条评论:
Also a cheat code to put IPS in a laptop that never came in it with the right hardware. I've done it before, but you can really only upgrade to IPS.
If you can find a nicer IPS matte screen for the same money as the "identical" screen used by the OEM and it works, I always upgrade them to matte IPS.
完成的
添加一条评论
添加你的答案
Falcon 16 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 185
