跳转到主内容
加入维修社区 - 创建账户
Kohler makes the gas powered engines for many different riding mowers & garden tractors both for home owners and professionals.
10 minutes then starts to surge,
my mower will cut for about 10 minutes then starts to surge, i have to stop blades then it will surge enough to get back to the shed with it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@billyhrawls what make and model is your mower and what have you checked?
完成的
添加一条评论
1个答案
Hello Billy, I have a similar problem with my mower. When your engine starts up, the carburettor closes the choke automatically. This causes a rich fuel mix. However, as the engine warms up, the choke opens up, and the engine begins to surge. It is more noticeable with the blades disengaged, as when they are engaged, it acts as a flywheel for the engine, reducing any fluctuations with RPM. This can be caused by several things.
1) clogged carburettor, this can cause an incorrect fuel to air ration, causing the governor(a little lever that controls the throttle/choke based off user input and rpm) to try and make up for this, overcorrecting, and throttling down.
2) The springs on your governor are loose, the tension is not right and there is slack in the system. This causes feedback when the choke opens up, causing it to overcorrect and undercorrect the throttle.
Try hosing the carburettor down with high pressure air, and if that doesn't work, get replacement springs for the governor.
Let me know how it goes!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Billy h Rawls 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 141
