跳转到主内容
加入维修社区 - 创建账户
Chrysler PT Cruiser 是一款由克莱斯勒设计并向全球市场销售的小型家用轿车/紧凑型 MPV,采用前置前驱布局。该车型提供 5 门掀背版(2000–2010 年)和 2 门敞篷版(2005–2008 年)两种车身样式。
Replacement turbo information needed
When replacing the Turbo, do you have to replace the sideman?Ifold that it's attached to as well , or can you just replace the turbo apand if so , what is the exact serial number or part description um for that Or where would I go to find that information
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Greetings Draco,
In this case yes as they are serviced as a single unit. I would also recommend changing the oil before replacing the turbo as well as the oil and coolant inlet and drain tubes.
You are going to be spending some money to replace this part on the car so it makes sense to do it properly or you will be doing it again at a greatly reduced lifespan and possibly a voided warranty on the turbo you purchase.
Order a replacement kit it comes with the oil and proper installation instructions gaskets, everything you need to perform this repair.
I don't know exactly what year you are referring to or what engine model. so the links below are just for reference and price examples. If you comment back the exact year and engine etc. I can find you what you need and send you a better link.
As always on the inside of the drivers door there is a sticker this sticker will tell you the exact month and year your car was manufactured. i.e 12/05 or 11/02 etc.
Turbo Kit for PT Cruiser - Cheap Non OEM
OEM 2005 Model - Expensive Option (
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Draco Quiles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 271
