跳转到主内容
加入维修社区 - 创建账户
TUF F15 发布于 2021 年,搭载英特尔酷睿 i7 处理器、NVIDIA GeForce RTX 显卡以及 15.6 英寸防眩光显示屏。
Replacement screen not working
Hi, laptop cant detect new screen. I also installed it without removing the battery since the guide i followed didnt either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's possible you shorted something by not removing the battery. In general, even if the guide doesn't say it, you want to make sure there's no power to the electronic components. Powering the device off isn't enough since residual power can still be supplied by the battery.
One way to rule this out is to turn on the computer by pressing the power button and connecting the device to an external monitor. If the external monitor shows a signal then you probably just have a bad display or something related to the connector on the board. Another way might be to reinstall the old screen if you still have it handy and the display is actually working.
这个答案有帮助吗?
得分 0
3条评论:
External monitor works, old monitor (kind of) works. Tried seeing if backlight is bad but cant see anything (which would make sense since the laptop cant detect it).
由完成的
If the backlight is bad, in most cases you can still see an image if you shine a light closely at it. Most devices can't tell that a backlight has gone out and will at least send an image to a display device.
When you say the old display works, what exactly do you mean by that? What drove you to replace the display in the first place?
Double check your connectors and if you aren't sure add photos to your original post and we can review it with you!
由完成的
Ahem, so it works... fully no issues.
All ive done is nothing... just booted it up for the lols and it works now... im speechless. Maybe its an introverted monitor?
由完成的
添加一条评论
添加你的答案
Tim Blomqvist 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 352
