跳转到主内容
加入维修社区 - 创建账户
一款由 BlackBerry RIM 在 2009 年发布的直板智能手机。
Signal Dropping when switched on?
When switching my device on I need to push the sim card with my finger to get it to actually get service. I used the device in the UK where 3g is still active however its an ex Verizon Model. is this a sim card reader error or a issue with the network on the device? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @lewisjohnston
If you need to exert pressure on the SIM card when it is inserted, try sticking an appropriate sized piece of tape on the back of the card and then insert it.
Hopefully this will force the card to make better contact with the SIM reader pins due to the extra thickness.
Perhaps initially leave a "pull tab" as part of the tape on the back of the card, making it easier to remove in case it is now jammed in the reader due to the extra thickness of the card and you wish to remove it for whatever reason.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lewis Johnston 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 227
