跳转到主内容
加入维修社区 - 创建账户
第四代 iPad Pro 12.9" 的维修与拆解信息。于 2020 年 3 月发布。型号为 A2229。
iPad Pro 12.9, USB Data Transfer Failure
iPad Pro, USB Data Transfer Failure
This is the iPad Pro 12.9-inch 4th generation model.
The connection to the computer via USB-C port is not working. My computer doesn't detect the ipad at all. (The same goes for ipad recovery mode.)
Currently, iPad is not a matter of computer trust because it has completed a factory reset.
I've also replaced the cable, but it's the same as the A to C cable or the C to C cable.
The symptoms are the same when I try on another computer (both Windows Desktop/laptop and macbook air M1)
Eventually, I disassembled the iPad and replaced the dock flex cable, but the symptoms didn't change. And I checked the logic board with a multimeter, but I couldn't check the short circuit/abnormal heat in components such as capacitors.(I have not yet checked the metal shielded part.)
Surprisingly, all other features are normal. There is no abnormal power off / panic full crash and the battery works well.
1. PD Charge - OK. Charging speed is also normal.
2. External Storage Connection - OK
3. External Monitor Mirrors - OK
4. USB-C Hub Connection - OK
I don't know the cause...Is it a failure of the USB IC?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I'm having the same kind of problem with my USB connects some things but not others now. Apple sucks.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wellbinnn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 323
