跳转到主内容
加入维修社区 - 创建账户
关于这款第五代 Apple iPad (Wi-Fi 版) 的维修指南、拆解和故障排除信息,有 32 GB 或 128 GB 存储空间可选。于 2017 年 3 月发布。型号为 A1822。配备 9.7 英寸 Retina 显示屏和 64 位 A9 处理器。
Charging socket not working
I bought the charging socket part to replace
I wanted to ask if there is anyone here who can explain how to change? Does it need soldering?
I would appreciate an answer
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The charging port seems to require SMD soldering with a heat gun or a hot plate from what I gather.
This is quite a complex procedure that requires soldering on the logic board, which is quite risky. If you do choose to fix it yourself, there are reference videos on Youtube for you to follow.
这个答案有帮助吗?
得分 1
2条评论:
@david56209
Can you get me a link to a YouTube video?
由完成的 分享
@elchanan1 https://www.youtube.com/watch?v=LbeuzkO5...
This one only includes the soldering part.
You will need to remove the logic board to access the solder pads for the Lightning port ribbon cable underneath it. You'll need to heat up the adhesives and be very gentle prying the digitizer and ribbon cables off.
This guide will take you up until that point:
iPad 5 Wi-Fi 逻辑板更换
Don't hesitate to ask if you have any doubts about the process.
由完成的 分享
添加一条评论
添加你的答案
Elchanan Blumenfeld 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 41
总计 406
