跳转到主内容
加入维修社区 - 创建账户
苹果的第四代无线键盘。发布于2015年10月。型号A1644。
Magic keyboard UP key broken
Hi, I have this keyboard. The UP key stopped working. I took of the keycap and the switch and also the small rubber dome. It's still not working. I can see some discoloration under it, like if it was burned.
Do you know what could it be? No matter what I do with a screwdriver it doesn't work. The DOWN key works when I slightly press it.
Is there any chance of fixing it, or I better keep it as a keycap donor for identical keyboards?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Doesn’t look good here😠
The metal clip is bent and it does look like there was a short (burnt part) did you try lifting the keycap a bit to aggressively here?
Apple treats keyboards and other input devices as throwaway as such they don’t offer parts and the construction is not conducive for repairability. Even still there are parts houses which do carry some parts in the UK there is a good one TheBookYard if you are on that side of the pond give them a try.
这个答案有帮助吗?
得分 0
2条评论:
Sure, I opened it too strong, but this keyboard was broken for a year or so, it was just in my drawer. I was just very interested in what could have happened to that UP key.
But how is this supposed to work? I mean when I press the rubber dome on the DOWN key, it works. What is touching what? All I see is a metal and a transparent foil on top.
由完成的
@zsoltero - Magic!
The rubber dome has a carbon disk which shorts across the two pads completing the circuit which in turn is converted into a signal the systems logic can interpret as that keys action.
由完成的
添加一条评论
添加你的答案
Zsolt Ero 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 32
总计 543
