跳转到主内容
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 个问题 查看全部
Unable to remove stripped screw from 3DS XL using screw extractor
I’ve decided to try and fix my 3DS as I have a bad B button. Upon opening the back panel I remove the battery and one of the screws is already stripped? I never taken this 3DS apart before and I think I made it significantly worst and I’m unsure on how I can get it out. I’ve spent money already on screw extractors but this 2mm extractor doesn’t seem to be drilling into the stripped screw. I’ve tried the rubberband but my screw driver and drill just go right through it and rips a hole. Anyone have any other ideas on what I can do??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
You can get steel-loaded epoxy putty which is very strong. It comes as a stick and you cut off a bit and nead it in your hands until the two parts are throughly mixed. Then press it into the screw head (clean it with isopropyl alcohol first to make sure there are no traces of grease). Before it sets, press a screwdriver bit into it to make a new screw head. Let it set for 24-48 hours then try with the same screwdriver bit, pressing as hard as you can.
这个答案有帮助吗?
得分 1
添加一条评论
@dirkhardpeck and if rubber bands and epoxy do not work, it'll be time to drill out the screw. First you need a bit the size of the inside of the Phillips head (red circle). That will keep the bit true and won't run off. Once you have that pilot hole drilled, get a slightly bigger bit (turquoise circle) and drill into the screw. It will not take long until the screw head will fall off. Once you have the casing deparated, use a pair of pliers to replace the rest of the screw,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tapioca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 46
