跳转到主内容
加入维修社区 - 创建账户
Patagonia 外套能让你在凉爽的天气保持温暖,在潮湿的天气保持干爽。维修难度从简单的破损修补到更复杂的挡风板维修不等。
Zipper pulled away from the jacket
The zipper still works on the jacket but on one side of the zipper the material pulled away. Suggestions on how to fix it?
It seem like the seams lost their adhesive and just pulled away
Update (02/23/24)
This is the only place that I can find it. But as you can see the zipper has pulled away from the seam
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@logandunn Can you upload a picture of the problem? 在已经存在的问题里加入图片
由完成的
I updated the original post to have the picture in it
由完成的
添加一条评论
1个答案
There are several adhesives suitable for fabric such as Loctite vinyl, fabric & plastic; E6000; Sew No More; or, Patch Attach which you might use. You might try taking two stiff wooden slats slightly longer than the length of the separation and two or (better) three clamps and, with the zipper open, spread a small amount of your chosen adhesive on the portion of the zipper that you want to adhere to the fabric (you don't want to put on so much adhesive that it squeezes out when you clamp it), put a wood slat on each side and clamp it all together. You can probably get away with using spring loaded squeeze clamps but you can use whatever clamps you have on hand.
这个答案有帮助吗?
得分 0
2条评论:
Oh, and if there is any old adhesive remaining on the separated area, you would want to do the best you can to remove it before making the repair. It's not obvious from your picture what kind of material you're working with so I hesitate to recommend a solvent. My go-to is acetone but I would be very cautious and try a tiny amount applied by the corner of a dried out alcohol pad. A product called Goo-Gone is probably safer than acetone and is also very good at removing adhesives.
由完成的
It also occurs to me that you might try contacting Patagonia and asking them if there is a particular adhesive that they would recommend.
由完成的
添加一条评论
添加你的答案
Logan Dunn 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 20
总计 486
