跳转到主内容
The bottom of the screen does not work
the bottom of my ipod screen does not work. when i try to touch an app at the bottom it does not respond. when i try to type a message the bottom row of keys will not respond. Help!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
jblisset, try a restore. Make sure you have a backup of your data. If the restore does not work, I believe that you are due for a new digitizer. The best way to replace it is by installing the complete assembly. Instructions are hereand the part is here. Hope this helps, good luck.
Replace a broken or damaged front panel assembly for your third generation iPod touch with this part. This asssembly includes the frame and home button.图片
产品
iPod touch (3rd Gen) Front Panel Assembly
$29.99
这个答案有帮助吗?
得分 0
3条评论:
Thanks the new screen worked!!!!!!!!
完成的
my ipod is the same but i havent been able to use any space or the symbol or anything else i can use the words but thats about it i think its the sensor is it time to get a new ipod or? its a 4 generation thanks
完成的
@marikah, replace the front display panel. It does sound like your digitizer is broken.
完成的
添加一条评论
how exactly do you restore?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jblisset 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 5,449
