跳转到主内容
Guides and support for various television (TV) brands and styles.
9091 个问题 查看全部
Screen fades to black after 5 minutes
My Vizio E55-E2 will power on and work fine. After 5 minutes the screen will begin to glitch (not backlight) and then the screen will fade to black. The audio is still playing.
If I use the remote to put the screen to sleep (it’s a vizio feature) and then press any button it will turn the screen back on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@christophe58813 since this happens after a short time, it is possible that this is a cold solder joint on one of your boards. since you still have audio my suspicion would be either the T-con board or the main board. Remove the back cover from your TV and visually inspect the boards. See if you find any obvious issue. Post some pictures of your boards with your Question so we can see what you see. It is also possible that this is a panel error but you'll have to rule out the boards first. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christopher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 54
