跳转到主内容
加入维修社区 - 创建账户
Repair information for the Creality Ender 3 Pro--an upgraded version of the Ender 3 3D printer, made by Creality. Released in September of 2018. Model number: Ender 3 Pro.
Why isnt my 3d printer scrolling button working
Scrolling button from my 3d printer doesen"t work, is there any way I could fix that myself ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
hi,
when you say it doesn't work;
-it doesn't turn?
-it turns but no scrolling action of the screen?
这个答案有帮助吗?
得分 0
3条评论:
yes, it moves but it isnt shown on the screen
完成的
Most of these random - out of nowhere issues are commonly caused by firmware corruption. A simple reflash of the firmware usually does the trick. Have you done any modifications? if so, double check your connections.
-Double check the ribbon cable connection from the LCD to the main board.
-inspect for broken, loose , burnt components.
-reflash the firmware.
-When i started having issues with my ender 3(after 2 years of use) I upgraded the board with the SKR mini E3 . Not only did it solved all my issues but the printing quality and performance improved as well.
完成的
thanks for your help
完成的
添加一条评论
添加你的答案
guy with 3d printer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 29
总计 496
