跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad T15 Gen 1 是一款 2020 年发布的商务型计算机,提供第 10 代 Intel Core i5 和 i7 处理器,并有多种显示屏、内存和存储配置可供选择。它可通过机器类型 20S6 和 20S7 进行识别,并配有 15.6 英寸显示屏、数字小键盘和 Lenovo 标志性的红色指点杆。
How to replace the motherboard?
How can I replace the motherboard and where can I buy it? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @nvh32299
What is wrong with the laptop that requires a complete motherboard replacement?
Here's the hardware maintenance manual for a ThinkPad T15 Gen 1 model (Machine Type 20S6 & 20S7)¹
Go to p.81 to view the procedure to remove/replace the systemboard².
There are 190 different systemboards compatible with the model. To get the same one as you have now, once you start to disassemble the laptop to remove the systemboard there should be a sticker or information on the board which shows the Lenovo part number for the board e.g. 5B20Z46023 or 5B20Z45923 etc.
Once you have found the part number on your board, search online for the part number only to find suppliers that suit you best.
If you have a ThinkPad T15 Gen 2 model (Machine Type 20W4 & 20W5)¹ here's the hardware maintenance manual for it. Go to p.83 to view the procedure to remove/replace the systemboard.² There are also 190 different systemboards available as well.
¹ The Machine Type (MT) number for the laptop can be found on the product information label on the bottom of the laptop.
² See the note in the systemboard removal/replacement procedure regarding inputting the exact brand name to identify the machine type i.e. Gen 1 or Gen 2 types when replacing the board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nvh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 49
总计 1,007
