跳转到主内容
Broken Battery Connector Replacement. Is this Usable?
My battery connector on my early 2015 13 inch macbook air broke off after an unfortunate accident. After doing a bit of research, I decided to try soldering a replacement on to my motherboard. I bought one on ebay but after it arrived, it was damaged. One of the pins at the end seems smushed and the little bump at the top of each pin (I dont know what its called) are all scattered and not aligned. Should I still try to solder it on the board or will it just not work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
@joseph72851 don't use a part that is doubtful. Get a proper replacement, that way you only have to do the job ones. No reason to use poor quality parts. As you already know, your part is a WTB-PWR-M82 conector and looks like it is readily available.
这个答案有帮助吗?
得分 0
添加一条评论
Are the bumps just solder? Likely a recovered part from a dead system.
Use a iron and solder-wick to remove them. I see no problems using a used connector here if the bumps come off.
Afterwards if it’s not working get a new one, I’m betting it will be fine!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
joseph 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 50
