跳转到主内容
The iRobot Roomba i7 is a robot vacuum which features dual spinning rubber brushes for maximum efficiency, cleaning pet hair and multi-surface floors.
New battery doesn’t charge up to 100%
I bought new battery from the iFixit store but even leaving it charging for a whole night it never reaches 100%.
I followed the instructions to mount it, holding the robot's buttons before inserting the new battery.
To be on the sure I did an hard reset of the robot but the battery does not fully charge.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@matteo80904 try what iFixit recommends: For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Now if you continue to have issues with the battery, I would suggest you contact iFixit. Since you bought the battery on iFixit, contact the service department: support.ifixit.com and let's see if they can help you further :-)
这个答案有帮助吗?
得分 0
4条评论:
I’ve tried using the robot until it shut off but when it’s low battery it goes automatically to charging base. Any suggestions on how to fully discharge?
完成的
@matteo80904 have you tried to disconnect the base so the robot can’t find it or it doesn’t charge
完成的
@oldturkey03 thanks, it took 3 hours(new battery brought big improvement) but the robot got fully discharged and now the battery has reached 100%.
完成的
@matteo80904 Awesome! Repair is War on Entropy!
完成的
添加一条评论
Im having issues with 2 different (both realtivly new) J7s i assume internals are the same as the i7 but both of them have intermittant charging issues where they both wont charge but after rebooting them they charge. should i try this method as well? to run it all the way then charge them?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matteo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 51
总计 613
