跳转到主内容
加入维修社区 - 创建账户
Dell Latitude 系列主要面向专业用途。该型号是 Dell 于 2018 年发布的一款 14 英寸笔记本电脑。Dell Latitude 5490 强调耐用性、便携性与安全性,并以其长生命周期而闻名。
Why it became hang
my pc become slower than before it hang alot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If your computer has been freezing/hanging a lot, there could be several causes. You may want to start with checking on how much space is left on your drives. If any of your drives are almost full, this can cause slower, worse performance, which can be solved by clearing some space on the drive. Before deleting files to free space, check to see if you have a second slot for an additional SSD (Solid State Drive). This will add more space.
Another reason could be due to a hard drive. These are mechanical, so they perform slower than modern SSDs. If you still have a mechanical hard drive, I recommend replacing it with an SSD.
Hope this answer helps your freezing/hanging problem. :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
asmaa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 248
