跳转到主内容
加入维修社区 - 创建账户
于 1994 年 12 月 3 日在日本发布,9 月 9 日在北美发布。型号包括 SCPH-100x、SCPH-3000、SCPH-3500、SCPH-500x、SCPH-550x、SCPH-700x、SCPH-750x 和 SCPH-900x。
Open button stuck even after cleaning
So for some reason one of the Ps1s that I have has a stuck open button. I took it apart, cleaned the button and socket, put it back together and the button still gets stuck. Maybe the spring is bad?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
or button too loose, as in diameter not quite large enough.. happened to me
由完成的
添加一条评论
1个答案
My solution to this problem was using a little bit of dry lube to let the assembly slip better. Another fix was sanding down the insert part where it makes the \___ shape at the end down to better work with the spring.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ryansrepairshop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 348
