跳转到主内容
加入维修社区 - 创建账户
苹果第五代智能手表,可选蜂窝网络版本,于 2019 年 9 月 20 日发布。
Destroyed Heat Dissipation Stickers
In order to remove the three display cable connectors, I completely destroyed the three pieces of extremely thin, black, heat dissipation (hd) stickers that covered each of the connections. I saw that ifixit carries a replacement hd sticker kit for the Series 6 44mm watch only. It’s out of stock so I can’t even try to adapt it for my Series 5. Is it absolutely necessary to replace the hd stickers? Is there an acceptable alternative hd sticker here on ifixit or on the internet I could use? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The tape is EMI shielding not heat. Finding the die-cut part is very hard.
The solution is to patch up what you have. I use this tape to patch things up Conductive Copper Tape 100% Pure Double Sided Adhesive Copper Foil Tape for Stained Glass, Guitars, EMI Shielding, Electric Connections, Repairs, Grounding, Crafts (1inch x 66FT)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Happy Dad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 306
