跳转到主内容
Repair information for Sharp televisions.
105 个问题 查看全部
SHARP LC-50LBU591U no image displayed
The tv was working but there were lines so I got a new t-con board and after changing it noticed I have no image but the led lights up oh and I also have sound i can hear the volume up n down ect... Any thoughts on what's wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@daac double check your work to make sure everything is properly connected. Check the T-con board to ensure you changed like for like. The other thing you want to check is if this is a backlight issue. Once your TV is on and you have sound etc. shine a flashlight beam at an angle against the screen. see if you can make out shapes, silhouettes etc. If so, it is your backlight that does not come on. that could be an issue with the power board as well as failed backlight strips. Try this is a darkened room since it will be more visible.
Of course, you can always post some pictures of all of your boards with your Question. That allows us to see what you see and hopefully help you further.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daac 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 12
