跳转到主内容
A 10 speed mixer made by KitchenAid in 2006.
20 个问题 查看全部
Seems to surge in power when under a small load, after replacing gears
My girlfriend's Pro 600 had started skipping gears it sounded like and after viewing a couple troubleshooting videos it seemed like we needed to replace a stripped gear or gears. When I opened it up there weren't any obvious damages but it did look like there was some wear on a few gears. We ordered and replaced basically all new gears from the motor to the planetary ring gear.
I installed all the parts as shown in the blown up picture of the mixer. Applied tons of fresh grease to everything, after detail cleaning all the old grease before replacing the parts. With no load it runs smoothly and sounds fine except a light knocking.
She tried her first cake mix in it and shortly after it started it would sound like it surged in power up and down. She was able to finish the batter but we're not looking to use it again until we can fix this problem.
Also, the video we watched showed the bushings installed with the flat sides perpendicular to the counter top but the blow up picture shows them parallel. I installed them the way the video showed but it does appear they could go either way.
Thanks for any help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@steveblackburn it would make sense, that under a load one of the shafts may buckle or jump and thus causes this type of behavior. Check the shaft for the bevel gear as well as the one for the motor dive. Make sure that those bushings/bearing are not having to much axial play. If nothing else, run it without the cover and see if you can "see" anything that doesn't move right. Just make sure you do this in a place where some grease splatters will not cause any domestic discussion :-)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Steve Blackburn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 118
