跳转到主内容
This is the Touchscreen version of the Lenovo N23 Chromebook.
it won’t turn-on
it wont turn on , i think it ran out of battery,the adabtor is working i tested it , but it wont recharge the battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@roozbehd check your power supply first
After that check your DC in Jack. Make sure there is no corrosion, damaged pins or debris in the jack. You can always use a few puffs of compressed air to clean it. If your power supply and your jack are okay, it'll be time to open your Lenovo up and check the DC in jack to ensure that it.
a. receives power from the power supply,
b. that everything is properly connected.
Now is also a good time to check the battery for any swelling etc. You should consider changing it since there is a possibility that his is/was one of the issues.
Use this Lenovo N23 Hardware Maintenance Manual to work on your Yoga
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
roozbeh d 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 55
