跳转到主内容
加入维修社区 - 创建账户
原始 '65 Twin Reverb 的 1992 年复刻版。与旧款型号不同,此复刻版采用了电路板和 1/4 英寸脚踏开关插孔。该型号具有经典的黑色面板外观和 12 英寸 Jensen 扬声器。
Dead Normal Channel - No Sound at All.
Hi - yes its the same amp which had the transformer issue. This time, in spite of the new transformer, the normal channel is silent. No sound when I plug guitar in. Here is what I have done so far. Aside from the transformer, I have also replaced, the filter caps, all tubes, retensioned the tube seats, cleaned seats, pots and jacks. The only sound I will get is when I run the guitar lead across my hand. Note, the guitar and lead works perfectly on the vibrato/reverb channel. What have I missed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@rheadelwell Can you upload sone pictures of the circuit board(s) inside? 在已经存在的问题里加入图片
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @rheadelwell
Is the V1A valve glowing or warm indicating that the valve has power at least to the valve heater?
Have you checked the V1A anode voltage is OK? It should be the same value as the V2A anode voltage
Does operating and releasing the Bright switch affect the audio when in Vibrato/Reverb mode and also Normal mode?
If operated it will turn Vibrato/Reverb off but not Normal
Check capacitor C18 is OK as well and not open circuit.
Everything after C18 is common to both the vibrato and normal inputs.
Here's the schematic that may help.
这个答案有帮助吗?
得分 2
4条评论:
Hi @jayeff so I have waltzed around the circuitry of V1 with a multimeter. All components measured correctly except for R4 which is on pin 1 of V1. R4 is supposed to be 100K however reads OC. This is on one of the anodes, so I would say that no voltage is reaching that this causing only half the tube to show voltage. Therefore the voltage is incorrect. Comparing to V2 where all measurements are correct. I did check C18 which was ok. So I'd say I have found the problem, or should I check anything else. Thank you for all your help to date.
由完成的
@rheadelwell
I'd say that you've found the problem, if it is the only one. You'll find out when you fix this one and then test if it works
No voltage on the anode of a valve means that there's no current flowing from the -ve cathode to the +ve anode of the valve, so no output from the valve
The input signal is on the grid of the valve and this directly affects the signal current leaving the valve i.e. output signal is an amplified version of the input signal.
Just curious as to why you unaccepted my answer though. was it not helpful at least to warrant an upvote score?
由完成的
@jayeff, sorry that was entirely unintentional. I'll rectify that as the answer did help.
由完成的
@rheadelwell
Thanks.
Cheers
由完成的
添加一条评论
添加你的答案
Rhea deLascy-Wells 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 43
总计 722
