跳转到主内容
加入维修社区 - 创建账户
本页面为树莓派3代B型的维修相关信息。该产品于2016年2月发布,型号:B。
Raspberry Pi 3B+: HDMI not working
Hi iFixers. I have a couple of Raspberry Pi 3B+ boards that are fully functional but don't detect and therefore don't show any picture over HDMI. It's not a software bug and the connector is fine. I'd appreciate any hints on what chip controls HDMI output on those boards - maybe I'd be able to replace it
Update (01/29/24)
After spending some time examining things around on the board I believe the fault might be due to the IC pictured below or the components to the right. Does anyone know what those are? Any hints would be greatly appreciated 🙌🏻
Update (01/29/24)
And one more weird detail - on the marked pin I get around 3V on the faulty boards instead of around 1,1V on a healthy one - what might cause this? Is this still that HDMI05-CL02F3 chip?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I wonder if LAN7515 C000 chip that controls USB and Ethernet on the Pi also related to HDMI 🤔. Any ideas would be greatly appreciated
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi @insympathy
According to the datasheet the IC only handles USB and Ethernet.
If possible, try tracing the connections back from the HDMI port and see what IC they connect to. Wondering if HDMI is incorporated in the main Broadcom SoC IC
这个答案有帮助吗?
得分 2
10条评论:
Hey, thanks for a hint - I already found that too.
Now the question is the following: Pi shows the graphical interface over VNC perfectly well, so my guess would be that graphical core does work. It's something between the SoC and the HDMI port that stops the party :)
由完成的
@insympathy
Don't know Raspberry that well but have you tried this
由完成的
Tried all of that, thanks, but sadly it seems that it definitely is a hardware issue
由完成的
@insympathy
You've probably already got this but perhaps check if there's 5V on pin 18 of the HDMI port
由完成的
You are absolutely right and I do get at least 4,7V on pin 18 :)
由完成的
显示更多的5条评论
添加一条评论
添加你的答案
in_sympathy 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 70
总计 983
