跳转到主内容
The camera was released in December 2007 and can be identified by model number S760. Fitted with a 7.2 Megapixel camera resolution and a 3.00x zoom lens.
How to open it after replacing the battery?
i recently just found my mom's old samsung s760:), and It's been awhile since she last used it. I added some new AA batteries and I pressed the power button thingy but it still wouldn't open. What do i need to do to open it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@aceleendin18659 make sure that there is no corrosion on the battery contacts inside the camera. Make sure that the battery door has all the contacts and is not corroded. After that you may have to open the camera up and take a look at the wiring and the DC-DC board. etc. Use these guides Samsung S760 to work on it.
On the bottom of your main circuit board is a power fuse. check that one for continuity.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aceleen Dinoniso Policarpio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 145
