跳转到主内容
加入维修社区 - 创建账户
购买日期:2018年2月9日 通过型号 BOV650XL/B 识别
E05 error and beeps - not usable anymore
After plugging it in, the LCD screen says E05 and just beeps, not allowing me to use it anymore. This code is not listed for troubleshooting in the manual. I called Breville and they said I need to ship it to them to diagnose the issue and then they will give me an estimate on the repair. Is this something I can do myself?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi @bige77075
Error code E05 indicates a Triac (electronics) board malfunction i.e. a power problem.
Open the oven and inspect the control board and the power board for any obvious signs of component failure or damage e.g. burnt out or heat stressed components.
Here's a video that explains how to open it that may help.
If you spot something or you're not quite sure, post some close images of the board, in your question, to get further help. Here's how to do this on ifixit 在已经存在的问题里加入图片
If you decide to replace a board here's a parts list that may help. Search online for the part number for the part (check if it matches what is printed on the board) to find suppliers that suit you best.
这个答案有帮助吗?
得分 0
1条评论:
Can also be caused by an over loaded circuit in your house. Breaker on verve of operating can cause the error.
完成的
添加一条评论
添加你的答案
Big E 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 51
总计 4,021
