installing a new blade
How to install a new blade on a Murray Lawn Mower model 20507x99c
the blade is attached to the engine via an adapter and a bolt that holds in onto the crank. Use either your own strength, or have someone hold the blade while you loosen the bolt on the bottom. You can also use a block of wood between the blade and the deck to prevent the blade from turning.Be careful that nobody gets hurt, use gloves or a rag to hold it. The tool to use would be either a box wrench or a socket. Sometimes those bolts are pretty tight and may require some extra torque to loosen. Hope this helps.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 487
