跳转到主内容
加入维修社区 - 创建账户
Lcd screen removed from phone
I dropped my phone on the floor and the lcd screen got removed from the phone
The phone was still working because it was still vibrating without the screen
How to fix
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
6个答案
最有帮助的答案
Hi Jess,
If the screen is completely separated from the phone now, then the flex cable that connects them together has been torn off. Unfortunately, that's not repairable so you'll need to replace the screen with a new one. I didn't locate any step by step iFixit style guides for you, but there is a YouTube video showing someone replacing a screen who appears to be in the very same situation you are with the screen detached to start with.
oppo reno a72 / a92 screen replacement and disassembly - YouTube
The screen itself appears to be relatively inexpensive as phone displays go and it looks like you can get it at several sites like Amazon, eBay and AliExpress, among others, according to what works for you. Here's an example from AliExpress of one that should work.
Original for OPPO A92 LCD Screen and Digitizer Full Assembly for OPPO A92 - AliExpress
If you decide to take this on, be sure to take lots of pictures as you work and when you're done you can use them to create your very own iFixit guide to this repair! It's easy, fun, and will earn the gratitude of the community.
Create a new Guide - iFixit
Good luck, and let us know how it goes!
这个答案有帮助吗?
得分 3
添加一条评论
My phone is oppo A9 2020 no drop my phone screen is bpacky
这个答案有帮助吗?
得分 0
添加一条评论
You can search in YouTube how to change LCD oppo a92 to a new one
这个答案有帮助吗?
得分 0
添加一条评论
Display change
这个答案有帮助吗?
得分 0
添加一条评论
Ganti LCD dengan yang baru
Indonesian->English translation:
Replace the LCD with a new one.
这个答案有帮助吗?
得分 0
1条评论:
See the Most Helpful Answer above.
English->Indonesian translation:
Lihat jawaban yang paling membantu di atas.
由完成的
添加一条评论
Saya sedang tidak ada uang dan saya sangat membutuhkan hp itu
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jess Domi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 57
总计 3,112
