跳转到主内容
Repair guides and support for televisions manufactured by Panasonic.
576 个问题 查看全部
Panasonic TX-40DS400E TV red light blinks once, backlight problem
Got a Panasonic TX-40DS400E flatscreen tv with a already damaged LCD screen (torn ribbon cable -> vertical lines on screen) and the 1 blink red light error. Im not really home in tv repairing but I tried my best.
Firstly I checked for any bad components on the boards but found none and then I checked the backlight LEDs, found 2 faulty ones which I soldered out and connected the rest. It was still throwing the same error. After that I tested the measure points on the P-board:
  • SRV24V: 25.8V
  • SRV16V: 16V
  • SRV5.3V: 5.27V
  • SRVLED went up to 51V, but decreased to 25.6V in standby mode
then on the A-board I could only measure the SRV-5.3V for 5.3V constantly, and the SRV-16V for 16V before going into standby mode.
I took a look at the backlight (3 strips) again and saw that the top strip which I took the 2 faulty ones out was turning on for a second, while the other two stayed for longer. (video explains better) But when I connected only the top strip, it stayed on for that duration like the other two.
What can I do at this point?
Update /2024.01.05./ Images of the A and P board, P board schematic diagram
TNPA6247 1P Schematic Diagram
And I found a service manual similar to this tv, all same boards, don't know if it's usable for this.
Panasonic TX 40DR400 Service Manual
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@doomsday524 looks like you still have some dead LED's on your strip. How are they connect parallel/serial or just serial? If so, then it make sense that they turn off.
Post some pictures of your board and lets see where you measure etc. That way we are all on the same page.
这个答案有帮助吗?
得分 0
5条评论:
Just checked the LEDs on the top strip individually, all works but two are dimmer than the others. Could those be the problem? The LEDs are in series, strips parallel.
完成的
@doomsday524 This looks so much like the strips. Personally, I would replace the top one at least.
完成的
Alright, I'll try that, thank you. It will take a few weeks for it to arrive, so should I leave the question open until then, or click on accept answer?
完成的
@doomsday524 absolutely leave it open until we know for sure things are resolved and properly working :-)
完成的
@oldturkey03 Hey it arrived, replaced the one which had the faulty LEDs and the tv works again. The only problem it has still, the panel, it only shows vibrating colors (https://youtu.be/1cFXtfM8LcA?si=2nuYmxX4...). The ribbon cable is damaged. Could i replace the panel with any 40" one?
完成的
添加一条评论
添加你的答案
Doomsday524 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 122
