跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad Gaming 3 15ACH6 发布于 2021 年,搭载锐龙处理器和 NVIDIA GeForce 显卡。这是一款入门级游戏笔记本电脑。
Keyboard swap tutorial anyone?
I spilled my drink on the keyboard and it sunk beneath the keyboard where the switches are located. Anyone know how to get to the keyboard to swap it because I don't want to stared disassembling things at random.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @aggelosgedeon
Do not try to charge or use the laptop and disconnect the battery from the motherboard as soon as possible to minimize the problems caused by liquids coming into contact with powered electronics.
After you have disconnected it, carefully check the motherboard for any liquid damage or even corrosion. If there is any, gently clean it way using Isopropyl Alcohol 99%+ available from electronics parts stores.
Here's the hardware maintenance manual] taken from this support webpage for the laptop.
Go to p.29 to view the procedure to remove the battery.
The keyboard is part of the upper case assembly and you will have to nearly completely disassemble the laptop to access it. See p.43.
Here's the parts list for the model that will help you find the correct replacement part. Click on Select Commodity → C-cover with keyboard (128) to find the part number for your model.
As can be seen there are 128 different keyboards available. They are language specific as denoted by the country code seen in the description for each assembly e.g. USA = United States, TUR = Turkey, THAI = Thailand etc. Also some have backlighting (RGB) wheres others don't. Usually the part number can be found on the underside of the assembly if you wish to verify that you're getting the correct one.
Search online for the part number only pertaining to your particular laptop variant, to find suppliers that suit you best.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Aggelos Gedeon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 54
总计 1,551
