跳转到主内容
6.1 megapixels, ISO 200-1600, DX format, 1.5x field of view crop
Screw stripped - Replacing the CF Reader
One of the side screws is stripped. Is there anything I can do to get it out?
I am thinking of grabbing some tacky glue or something to make it easy to unscrew ( fill the void that was created ). I am open to suggestions and help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@ilabbe the most common reasons why those strip is because they are to tight. You will need more torque to get it out. I have never had any luck with the "home remedies. I use a rotary tool (Dremel) and a drill just slightly larger than the threaded part of the screw. The center punch the screw head and start drilling the old screw out. Sometimes it's enough to just drill the screw head off and then later (after you disassembled the case) to use a pair of pliers to remove the rest of the screw. All it takes is a bit of patience and not to drill to deep etc. Haste makes waste :-)
这个答案有帮助吗?
得分 2
1条评论:
Haste makes lots of waste!
Thanks!!
完成的
添加一条评论
添加你的答案
Jonathan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 131
