跳转到主内容
Released January 2020, identified by model numbers SM-A015F, SM-A015F/DS, SM-A015G, SM-A015G/DS, SM-A015M, SM-A015M/DS, SM-A015T1, SM-S111DL, SM-A015V, SM-A015A
47 个问题 查看全部
Mengapa speker saya suarannya samarsamar My speaker sound faint
Speker hp saya itu suarannya dah rusah
Kalau mengunakan hadsed suarannya bagus tapi kalau di lepas suarannya samarsamar ataupun suarannya tidak enak di dengar.
Translation (Indonesian)
My cellphone speaker has broken sound
If you use a headset, the sound is good, but if you take it off, the sound is faint or the sound is not pleasant to hear.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@annasitumorang start off by cleaning the speaker grill. Those speaker openings are very small and a lot of debris collects in those. If that does not work, you may need to consider replacing the speaker.
Since iFixit does not yet have a guide for this. Use something like this video to get to it. You do not have to mess with the main board. After the initial opening go to 2:12 to see how to remove the speaker assembly. Replacement speakers are readily available online. Just select a speaker that is for your exact model.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anna Situmorang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 48
