跳转到主内容
加入维修社区 - 创建账户
How to change the RAM modules, SSD slots?
Hello I would like to have a guide on how to add an extra SSD (not sure what type of SSDs are supported) and how to upgrade the RAM on this device.
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @georgesaade
Here's the hardware maintenance manual, taken from this support webpage for the laptop.
The laptop supports two SSDs, - see p.32 → p.33, however 1 M.2 slot is a PCIe 3 x 4 (Gen.3) and the other is a PCIe 4 x 4 (Gen.4), so if you get Gen.4 PCIe SSDs then it will work in both slots as it is backward compatible with Gen.3 but will work at Gen.3 speeds if it is inserted in the Gen.3 slot.
At the moment Gen.4 SSD are more expensive per GB as compared to Gen 3 SSD e.g. 1TB Gen 3 SSD = ~$US85, 512GB Gen 4 SSD = ~$US75. so this may decide which version to get
See p.34 to view the procedure to remove/replace the memory modules. The laptop supports up to 64GB of DDR4-3200 ram in 2 slots i.e. 2 x 32GB
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
George Saade 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 397
