跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone。维修过程简单直接,但前面玻璃和 LCD 必须作为整体单元更换。GSM / 8、16 或 32 GB 容量 / 型号 A1332 / 黑色和白色。本页面旨在帮助用户对 iPhone 4 进行故障排除、维修和寻求帮助。
iPhone 4 power button issue
So I own this iPhone 4 and it fell out of my hand and then the power button is so hard to press! Can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Pawel,
You can almost certainly fix this yourself, and iFixit even has all the guides you need to do that job.
The biggest problem here is that first you'll have to figure out which part is broken. The power button consists of a mechanical button, the part you press with your finger, and then there's the electrical part which is basically a small metal dome that the mechanical button compresses to make the electrical connection. The two parts require very different approaches to fix; it's not too bad of a job to replace the mechanical part, but if its the electrical domed switch itself you have to pretty much gut the phone to get to it.
I'd suggest following the guide to replace the mechanical button first, and once you get to the part where you remove the electrical switch, you can evaluate whether it's the mechanical or the electrical part that's gotten damaged. It could even be just the bracket that holds the electrical switch in place that's been bent. If it's just a bent part, you may be able to straighten it, but if something's broken you may have to order parts, which should be pretty easy to get.
Here's the guide for the mechanical part of the button.
iPhone 4 Power & Lock Button Replacement - iFixit Repair Guide
If that doesn't do the job and you end up needing to replace the electrical switch, then use this guide to do the repair.
iPhone 4 Power & Sensor Cable Replacement - iFixit Repair Guide
As far as parts, like I said they shouldn't be hard to find; I'd suggest starting out checking Amazon, eBay and AliExpress, depending on where in the world you're located and what's available to you.
Good luck; let us know how it turns out!
iPhone 4 电源按钮图片
指南
iPhone 4 电源按钮更换
难度:
困难
15 - 30 minutes
iPhone 4 电源与传感器线缆图片
指南
iPhone 4 电源与传感器线缆的更换
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Pawel C 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 27
总计 332
