跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 个问题 查看全部
GPU upgrade/replacement, SSD upgrade and CPU upgrade
Hi there!
I have a late 2015 iMac 27" and I was wanting to do a few things to it. Its current specs is the base model
What is the max gpu I could put inside the iMac even if I have to modify it?
Would I have to install drivers and how would I do it? Could I put an NVIDIA card inside the iMac?
Secondly I want to put an SSD inside it. Is it just as simply as placing a 3.5inch ssd into the SATA port or is there something else I have to do as well?
As I cherry on the top, what is the most powerful cpu I could put inside it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The GPU chip is soldered in unlike the older MXM models in the 2011 and older iMacs. So, you would need a logic board swap out to get the high end Apple offered. Not really worth it.
You have two options the SATA port as well as a custom blade SSD refer to these guides
As far as CPU you are limited to what Apple offered for this series 4.0 GHz Core i7 (I7-4790K)
iMac Intel 27" Retina 5K Display 硬盘图片
指南
iMac 因特尔 27" Retina 5K 显示屏 硬盘更换
难度:
中等
1 - 2 hours
iMac Intel 27" Retina 5K Display Blade SSD(固态硬盘)更换图片
指南
27英寸 5K Retina 显示屏 iMac 固态硬盘SSD 更换
难度:
困难
2 hours
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Z S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 12
