简介
如果你的iMac是用固态硬盘 SSD 或 Fusion Drive 来做存储设备的,这些iMac在逻辑板后面有一块SSD。使用本指南来移除或更换SSD。
“在开始做工作之前,先拔掉电脑和按下电源按钮,用10秒钟的时间来释放电源的电容器。”
“要非常小心”,不要触碰电容器的引线或电源后面的任何暴露的焊接接头。
为了重新组装你的设备,请按照指示进行反向操作,并安装我们的[指南|30512|adhesive strip replacement guide]来重新连接显示器玻璃。
216等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
120条评论
Does it mean that I can install Mavericks to the new hard drive rather than Yosemite for imac retina new model. I really dont like Yosemite.
ulas sunar - 回复
Hello,
So i have maxed out version of 2014 iMac 5k with 3TB fusion drive. I am looking to replace above described SSD with crucial 920 gb ssd. Is there other brands of compatible ssd's you would recommend? Will this new ssd still act as fusion drive or can I install OS X separately on it?
Thanks
If I want to swap the fusion drive with a SSD, do I need to remove the SSD-part of the fusion drive as well or can it be left behind?
Yes - you can leave it behind but at some point you will need to reformat and break the fusion into the 2 separate drives that actually there. Please backup first as this is a data destructive operation.
Chip T -
