跳转到主内容
The LG V40 ThinQ Android smartphone was released in October 2018. The V40 was LG's first smartphone to feature five total cameras.
Touch input rapid ghosting, but sometimes works.
So this phone has been fine and then very suddenly wasn't. I woke up this morning and unlocked with the back fingerprint sensor to turn off the alarm and the phone wasn't responding. I have the setting turned on to see touches I guess and I can see rapidly reporting touches all along the edges of the screen. It pulled up lots of apps, was hitting the home button back constantly, and nearly sent a text. All extremely quickly.
I held down the buttons to restart the phone and it does the same thing on the password input before it fully boots.
I wiped the phone very thoroughly and managed to get back into the phone once, but it messed up again.
misc info
No contact with moisture. the phone has had some flex for a while as if it gets stored in a back pocket, but that has never been the case. It is very minor and may have been present from a previous owner after refurbishment.
I need back into this phone at least once as I'd like some of the newer photos and recordings that haven't been backed up.
I've ordered a new phone, so time isn't a huge issue. I'm wondering if it's possible to disconnect the touch sensor and just use another input through USB C, but that will need to work before booting into the OS to be helpful.
Any ideas are appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@sarahsaffel "Ghost Touch" is most commonly caused by a failure of the digitizer and the display panel. Replacing the display assembly will most likely fix it. Remember that "has had some flex for a while" could just be enough to cause the failure of the assembly. The only other things is that you want to remove your screen protector, if it has one, and try again.
Of course you can also do a factory reset of your phone but make sure you have everything backed up and that you remember all of your passwords etc.
Since iFixit does not have a guide for this, use something like this video to work on your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarah Saffel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 250
