跳转到主内容
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
UMD laser does not turn on regardless of drive
The laser on the PSP 1000 doesn't turn on but its spins, the laser moves and tries to focus, I except its an issue on-board. I don't want to replace the board, instead try component level fix. I understand their are tons of components to check along with way but what is the most common point of failure for this specific issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@kickflipa180 there really aren't any common points for this, The most common issues were Firmware issues. Check the PSP forums for that.
After that, you can check your motherboard for any damaged, missing or charred looking component. Post some well focused and large enough images of your motherboard with the Question. That way we can see what you see and maybe identify an issue, 在已经存在的问题里加入图片 Pay particular attention to componets around CN9501 and IC9501 and 9502 and CN9503
这个答案有帮助吗?
得分 1
3条评论:
After your mention of firmware being a common issue, I tried my best efforts to check if that is indeed the issue and IT WAS! Thanks for setting me on the right path friend :)
完成的
How ? What did you do ?
完成的
Hey KickFlipa180 3-343 did you find your fix?? Having the same problem would appreciate ANY help!!
完成的
添加一条评论
添加你的答案
KickFlipa180 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 31
总计 665
