跳转到主内容
Would like to change my motherboard
My msi stealth gs75 9sg graphics card died. In device manager it has a code 43 and a nvnvlddmkm blue screen error code along with a SYSTEM_THREAD_EXCEPTION_NOT_HANDLED blue screen error. I did everything possible including the DDU.
I want to know if I can swap my motherboard with the exact same specs and motherboard set up. On ebay there are some exact motherboard models. I wanted to know if it is safe and okay to replace my motherboard?
Laptop specs
Model: Msi Stealth gs75 9sg
Gpu: Rtx 2080 max q
Cpu: i7 9750h
Ram: 32gb ddr4
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@kentracerd38110 yes, it is absolutely okay to switch like for like. If you found a motherboard with the same specs and numbers as your, it is okay to switch it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
KenTracer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 80
