跳转到主内容
The phone does not turn on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
完成的
添加一条评论
1个答案
最有帮助的答案
@shajinali you are not giving us a lot to work with here. It would be nice to know what you have checked or what you have tried to fix it. Anyhow, first you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up.
I would follow the Samsung troubleshooting flowchart
. Use this document Component Layout and the search function on your PDF reader to find the components to test.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
shajinali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 141
