Why battery draining down fast
Battery draining fast
Hi @aijazahmed
Try replacing the battery and check if that resolves the problem.
Here's a video that shows what to do.
Search online for B-H0 battery to find battery suppliers that suit you best.
这个答案有帮助吗?
First, check if the battery is bloated or not if it is bloated change it with a similar 4500mah battery.
If the battery is not bloated first change the app's background running setting to off from setting and stop other background processing you don't want.
Next, stop all unnecessary notifications and turn on the dark mode it boosts your phone battery life.
If it didn't work try replacing the battery and check if that resolves the problem.
这个答案有帮助吗?
过去 24 小时: 6
过去 7 天: 23
过去 30 天: 117
总计 2,708
9条评论
Battery drains fast I am vivo phone
由 kishore kishore 完成的
@kishorekishore How old is your battery? Is this something new or has it been getting steadily worse? Have you considered @jayeff's advice to replace the battery?
由 Jerry Wheeler 完成的
Battery drain fast
由 Hashir Siddiqui 完成的
Battery draining issue
由 Gangadharaiah R 完成的
Very bad battery
由 Saguna Raghav 完成的
显示更多的4条评论
