跳转到主内容
加入维修社区 - 创建账户
Bose Sport Earbuds 让你的音乐听起来就像歌手在你身边一样,激励你多跑一英里或多做一组运动。获得专利的声学端口设计和高性能优质驱动单元相结合,在小巧的声学封装内提供了出色的音质。
Power problems and unable to update
My earbuds got 3 flashing lights on the case and after using the Bose updater on PC they are not recognized by the case and the case thinks the earbuds are out of the case. Therefore I can not update them. Tried to reset the case using the Bluetooth button but the earbuds flash only once. When opening the case both the lights on the case and the lights on the earbuds do not work. When charging the lights out of the five on the case flash(1st, 3rd, 5th,). After a while only the first light starts flashing as if the case is charging but after a few hours only the first light is on. When unplugging and then replunging the case to the power source the same cycle happens 3 lights flash and after some time only the first light flashes(as if the case is charging). Any ides on what is this problem about will be well appreciated!
Thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
The batteries are dead and you need to replace them. I was hoping somebody haf managed to do the replacement so i could get started.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Philippe Ainouz (Phosmo) 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 46
总计 1,206
