跳转到主内容
加入维修社区 - 创建账户
PlayStation Portal 是一款便携式手持设备,允许用户通过 Wi-Fi 从 PlayStation 5 游戏主机串流游玩游戏。该设备发布于 2023 年 11 月,型号为 CFI-Y1001.
Dpad stops responding after multiple inputs
Whenever I move from side to side quickly on my dpad and then hold on the last input, it stops responding until i release the button and press it again. This doesnt happen with the joystick. Im not sure if this is a software issue but I did take mine apart to have a look and didnt see anything obviously wrong or misaligned internally. I dont think its a streaming or lag issue because I can replicate it with the brightness slider from the portals system settings. Is there a hardware issue that I should be looking for that may cause this? I did notice that the blue ribbon under the silicone cap was a little lose and not touching the board on one side but not sure if that would cause this or what to use to secure it to the board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I didn't know what a Playstation portal was until now, so thanks for introducing me to that.
I think the problem might be with that ribbon. That is all my limited experience can tell you, as I don't know how to fix that.
这个答案有帮助吗?
得分 0
1条评论:
I found a video for a teardown on YouTube and the guys ribbon cable looks a little loose as well. Around 4 minutes in.
https://youtu.be/qQvzinHu04s?si=LLuUuTLA...
Maybe it’s a software issue, I may try replacing the dpad itself, it looks to be the same as the ps5, but in the meantime I’ll not play any games that need quick dpad movements. Everything else works great so far.
由完成的
添加一条评论
添加你的答案
loudog999 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 685
