跳转到主内容
加入维修社区 - 创建账户
Acer Nitro 5(型号 AN515-51)于 2017 年发布,是一款配备英特尔酷睿 i7 处理器和 Nvidia GTX 1050 Ti 显卡的游戏笔记本电脑。
How to add more RAM
How to add more RAM to my laptop
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Run your laptop's model number in google with "ram" in the search, do a bit of digging around. Most of the time the easiest way to find it is to unscrew the little screws on the back of your laptop (put them into a baggie, as you will need them to put back!) and gently pop off the back cover. If you have to pull hard at all, you missed screws. Look for the ram module (kinda like a thin pack of gum with a shiny wing) that is clipped into the board. There will be numbers on it kinda like (8GB 1Rx8 PC3L), search for them (google/newegg/microcenter) and simply either add a second module of the same type to double your ram if there's an empty slot, or replace all of them with a higher capacity. Always check that you put all cables back and things boot up fine before you screw everything back together.
Best of luck with your project,
Dan
这个答案有帮助吗?
得分 0
1条评论:
Okay, I Will try it Thanks for the answer. maybe you have some pictures to make me easy
由完成的 分享
添加一条评论
添加你的答案
Andy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 63
总计 686
