跳转到主内容
加入维修社区 - 创建账户
Samsung RF28HMEDB 是一款 28 立方英尺的法式对开门冰箱,配有底部冷冻抽屉。冷藏部分容积为 20.06 立方英尺,冷冻部分容积为 7.94 立方英尺。该冰箱采用 Twin Cooling Plus® 技术,配备可转换的 FlexZone 抽屉、LED 照明、防溢搁板、大容量门架以及两个湿度可控的保鲜盒。
Ice maker button problem.
On the display, the Ice maker on and off keeps flashing over and over (with a super annoying beep), the only way to stop it is to push the control lock button. Any ideas to a cause? Everything else about the fridge seems to be working fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @richardlass3126
Here's how to run the Self-diagnostic function during normal operation tests, from the service manual.
Run the diagnostics and check what error codes show. The code meanings are on the following pages in the manual.
Hopefully a start to find out what's wrong.
这个答案有帮助吗?
得分 0
2条评论:
After running the mentioned diagnostic, no error codes came back. I wonder if this is a panel issue.
由完成的
@richardlass3126
Try following the flowcharts on p.98→p100 and check the results
由完成的
添加一条评论
添加你的答案
Richard Lassitter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 263
