跳转到主内容
The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
My phone always restart
my phone age was 2 years, and now always restart every time
how it be and how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@rahmanf could be a software issue. Try a reset of your software. Remember to make sure that all of your files are backed up etc. Also, check if this happens in safe mode as well or if it stays on. To get into safe mode use this site. If none of that helps/works, I would start by replacing the battery and making sure that your charging port works, once you replace the battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rahman f 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 18
总计 330
