跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
424 个问题 查看全部
Screen is Black, I can see image with flashlight
Hi, I have just replaced the screen on a macbook air 2017 and have the a black screen issue.. but if i shine a torch on the apple logo at the back i see that its booted and at the login screen so the screen works its just seemingly got a backlight problem.. how do i troubelshoot and fix that?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I would do a careful inspection of both sides of the logic board looking for corrosion damage. Don't forget the display cable and connectors. Review this guide MacBook Air 13" Early 2017 Upper Case Replacement you shouldn’t need to go past Step 30. Clean off any corrosion damage you see, if needed touch up the solder joints make sure you use flux and don’t create any bridging.
If that fails to fix things then you'll need trace the logic from the start on the logic board using a DVM and a set of schematics and boardview drawings to isolate out where the backlight power is lost as well as ID the damaged part.
This might be beyond your skill set
这个答案有帮助吗?
得分 0
添加一条评论
@martinrobertson start off with the easy things. Let us know what exact model your logic board is. It should be a 830-00165 but we just want to make sure. Of course, you do need to perform a visual check of the board first. Check for corrosion, as well as missing or burned looking components. The first thing you need to determine is, if you have power to your backlight. For that, check the voltages on your display connector. With your multimeter set to 50VDC (or close to it depending on your meter), Black to ground, Red to pins 3 or 4 and meter in volt mode, you should get around 30V or higher on a good working system. If you do not have any voltage, check the fuse, as well as the power transistors etc. If the voltage is low but there is power, you need to check your boost circuit. Post some images of your board with your Question. That way we can see what you see 在已经存在的问题里加入图片
Save the images for now since you never know what can happen to this answer, so they may disappear :-) Once we know what your tests tell you, we can probably guide you a bit more in regards to the components etc. Nothing is easy but anything is possible. After all, you are coming to iFixit for some help on this and let;'s see if we can at least narrow it down for you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Martin Robertson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 39
