My display is not visible.
My laptop Screen is not visible when in insert any external RAM, once i remove the External RAM then it works properly, but the laptop will be getting slow
try pressing Windows logo key + P
and change between the screen and see what happens
这个答案有帮助吗?
@manishrana97157 your question is somewhat cryptic. Let us know what "External RAM" you are using and where do you plug it in to. Since your display stops working when this is connected, it appears that there is a conflict and you can't use this "memory". Your Lenovo IdeaPad 3-15IML05 has 4GB of standard memory and can be expanded to a maximum of 12GB, so not sure why you would use "External RAM" instead of adding proper RAM.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 29
