跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad 110-15ISK 由联想于 2015 年在美国开发。可以通过型号 80UD 来识别这款 Lenovo IdeaPad 110-15ISK。
Second Graphics card not detected
For me, The AMD Radeon card which comes as the second graphics card in this laptop, has completely disappeared in the system. Task manager, Device manager, or dxdiag do not recognize it, and amd driver installer doesn't detect it either, the copy of linux I also have installed on the system, doesn't recognize it either. I haven't opened it and would rather not. What do you think could be the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @amiratashi
Perhaps check in BIOS to see if there's an option to disable the AMD GPU.
If there's not, there's some reason why the GPU is not communicating with the I/O chipset on the motherboard so you will have to open it up and see if anything obvious is wrong. After that you may need the schematics to find out what's happened.
Here's the hardware maintenance manual that will help gain access to the motherboard
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your anwser @jayeff
完成的
添加一条评论
添加你的答案
Amir Atashi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 431
